采用LED专用主控芯片WS2812,支持单总线控制,仅需一根管脚即可控制所有LED,并且模块支持级联控制,可以多个模块同时控制,不占用管脚资源。可实现256级亮度显示,16777216种颜色的全真色彩显示颜色。
- 通讯方式:单总线控制
- 功 率:0.3W/颗
- 灰度等级:256级
- 16777216种颜色的全真色彩
- 支持级联控制
| VCC |
| NC |
空脚
| DI |
控制数据信号输入
| GND |
| VCC |
| NC |
空脚
| DO |
控制数据信号输出
| GND |
当多个模块需要级联时,把上一个模块的DO连接至下个模块的DI!
RGB LED库文件下载
//程序功能:依次按照红绿蓝点亮LED灯//
// This is a demonstration on how to use an input device to trigger changes on your neo pixels.
// You should wire a momentary push button to connect from ground to a digital IO pin. When you
// press the button it will change to a new pixel animation. Note that you need to press the
// button once to start the first animation!
#define PIXEL_PIN 7 // Digital IO pin connected to the NeoPixels.
#define PIXEL_COUNT 10 //级联数量
// Parameter 1 = number of pixels in strip, neopixel stick has 8
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_RGB Pixels are wired for RGB bitstream
// NEO_GRB Pixels are wired for GRB bitstream, correct for neopixel stick
// NEO_KHZ400 400 KHz bitstream (e.g. FLORA pixels)
// NEO_KHZ800 800 KHz bitstream (e.g. High Density LED strip), correct for neopixel stick
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
strip.setBrightness(50); //调亮度
strip.begin();
strip.show(); // Initialize all pixels to 'off'
for(uint16_t num1=0;num1<PIXEL_COUNT;num1++)
strip.setPixelColor(num1,255,0,0); //设置红色
strip.show(); //显示
delay(500);
strip.setPixelColor(num1,0,255,0); //设置绿色
strip.show(); //显示
delay(500);
strip.setPixelColor(num1,0,0,255); //设置蓝色
strip.show(); //显示
delay(500);
MicroPython示例
import neopixel
import math
np=neopixel.NeoPixel(pin0,4) #pin0为控制引脚,级联4个RGB
for i in range(4):
np[i]= (255,0,0) #设置4颗灯珠显示颜色,颜色为红
np.show() #刷新显示颜色
for i in range(4):
np[i]= (0,255,0) #设置4颗灯珠显示颜色,颜色为绿
sleep(1000)
np.show() #刷新显示颜色
for i in range(4):
np[i]= (0,0,255) #设置4颗灯珠显示颜色,颜色为蓝
sleep(1000)
np.show() #刷新显示颜色
sleep(1000)
| 注意:彩灯位置是从"0"开始计算,第一个为np[0]
| 程序功能:让RGB LED灯依次发出红绿蓝三种颜色的光
| Version |
Date |
Note [+]新增[-]删除[^]修复
