斜不胜正灯
本作品可通过触发倾斜传感器改变彩色RGB灯带颜色。使用时先根据制作说明将作品组装完整,然后接上 电源(9V电池或USB供电),打开主控板开关,触发倾斜传感器即可。本作品用倾斜传感器作为输入装置, 彩色RGB灯带作为输出装置,可自行编程改变颜色、变换方式、灯带数量等。DIY动手组装,锻炼动手能 力,了解智能创意电子套件的使用,激发创新思维,增加学习乐趣。
将灯倾斜触发后,程序控制17颗灯珠渐变颜色。灯回正后,灯带停止渐变颜色。
电子模块清单
| 模块名称 | 数量 |
| W1控制板 | x1 |
| 倾斜开关 | x1 |
| RGB灯带(17颗) | x1 |
电子模块连接说明
| 模块 | 引脚 | 说明 |
| 倾斜开关 | W1-9/10接口 | |
| RGB灯带(17颗) | W1-7/8接口 |
Arduino程序/图形化程序
| 斜不胜正灯程序包 |
#define SWITCHPIN 9
int numpixelsPin = 7;
#define nusec 5
#define NUMPIXELS 20
int num;
uint8_t r,g,b;
uint16_t h;
int led = 20;
int fz=0;
int flag=0;
int flag1=0;
int i = 0;
uint16_t cnt = 0;
Adafruit_NeoPixel pixels1 = Adafruit_NeoPixel(NUMPIXELS, numpixelsPin, NEO_GRB + NEO_KHZ800);
void HSV2RGB(uint16_t h, float s, float v, uint8_t * r, uint8_t * g, uint8_t *b);
pinMode(numpixelsPin,OUTPUT);
pinMode(SWITCHPIN,INPUT);
digitalWrite(numpixelsPin,LOW);
pinMode(nusec,OUTPUT);
digitalWrite(nusec,HIGH);
pixels1.begin(); // This initializes the NeoPixel library.
for(num = 0; num < led; num++)
pixels1.setPixelColor(num, pixels1.Color(0,0,0)); // Moderately bright green color.
pixels1.show(); // This sends the updated pixel color to the hardware
pixels1.setPixelColor(num, pixels1.Color(128,0,0)); // Moderately bright green color.
delay(65);
for(num = (led-1); num >= 0; num--)
pixels1.setPixelColor(num, pixels1.Color(0,128,0)); // Moderately bright green color.
delay(65);
pixels1.setPixelColor(num, pixels1.Color(0,0,128)); // Moderately bright green color.
delay(65);
// Serial.begin(115200);
if(digitalRead(SWITCHPIN))
h += 2;
if(h>360)
h=0;
HSV2RGB(h, 1.0, 1.0, &r, &g, &b);
pixels1.setPixelColor(num, pixels1.Color(r,g,b)); // Moderately bright green color.
digitalWrite(nusec,LOW); //ying yue
delay(50);
digitalWrite(nusec,HIGH); //ying yue
delay(50);
uint8_t hi;
float f, p, q, t;
hi = (uint8_t)(h / 60);
f = (float)h/60 - hi;
p = v * (1 - s);
q = v * (1 - f * s);
t = v * (1 - (1 - f) * s);
switch(hi)
//0: {r,g,b} = {v,t,p}
case 0:
*r = v * 255;
*g = t * 255;
*b = p * 255;
break;
//1: {r,g,b} = {q,v,p}
case 1:
*r = q * 255;
*g = v * 255;
*b = p * 255;
break;
//2: {r,g,b} = {p,v,t}
case 2:
*r = p * 255;
*g = v * 255;
*b = t * 255;
break;
//3: {r,g,b} = {p,q,v}
case 3:
*r = p * 255;
*g = q * 255;
*b = v *255;
break;
//4: {r,g,b} = {t,p,v}
case 4:
*r = t * 255;
*g = p * 255;
*b = v * 255;
break;
//5: {r,g,b} = {v,p,q}
case 5:
*r = v * 255;
*g = p * 255;
*b = q * 255;
break;
default:
break;
