PH传感器
用于检测量溶液PH值酸碱度的I2C通讯类的传感器
- PH值范围 : 0~14
- 解析度: 0.1
- 精度: 2%
2、测量时,将PH电极接入模块,将电极探头放入被测溶液中。
- GitHub:bluebit for mPython library
- bluebit for mPython library API: https://mpython-lib.readthedocs.io/zh/master/bluebit/index.html
from mpython import * # 导入mpython
import bluebit # 导入bluebit 模块
meter=bluebit.DelveBit(0x60) # 实例模块,根据实际I2C地址修改
value = meter.common_measure() # 测量
sleep_ms(200)Arduino
reading = Wire.read(); // receive high byte (overwrites previous reading)
reading = reading << 8; // shift high byte to be high 8 bits
Serial.println(reading); // print the reading
Serial.begin(9600); // start serial for output
}microbit
