4RGB LED
单板级联4颗RGB灯珠,采用LED专用主控芯片WS2812,支持单总线控制,仅需一根管脚即可控制所有LED,不占用管脚资源。可实现256级亮度显示,16777216种颜色的全真色彩显示颜色。
- 通讯方式:单总线控制
- 功 率:0.3W/颗
- 级联4颗灯珠
- 灰度等级:256级
- 16777216种颜色的全真色彩
| NC | 空脚 |
| DI | 控制数据信号输入 |
// 程序功能:控制4个RGB灯依次按红绿蓝颜色点亮//
// This is a demonstration on how to use an input device to trigger changes on your neo pixels.
// You should wire a momentary push button to connect from ground to a digital IO pin. When you
// press the button it will change to a new pixel animation. Note that you need to press the
// button once to start the first animation!
#define PIXEL_PIN 7 // Digital IO pin connected to the NeoPixels.
#define PIXEL_COUNT 4 //级联数量
// Parameter 1 = number of pixels in strip, neopixel stick has 8
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_RGB Pixels are wired for RGB bitstream
// NEO_GRB Pixels are wired for GRB bitstream, correct for neopixel stick
// NEO_KHZ400 400 KHz bitstream (e.g. FLORA pixels)
// NEO_KHZ800 800 KHz bitstream (e.g. High Density LED strip), correct for neopixel stick
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
strip.setBrightness(50); //调亮度
strip.begin();
strip.show(); // Initialize all pixels to 'off'
for(uint16_t num1=0;num1<PIXEL_COUNT;num1++)
strip.setPixelColor(num1,255,0,0); //设置红色
strip.show(); //显示
delay(500);
strip.setPixelColor(num1,0,255,0); //设置绿色
strip.show(); //显示
delay(500);
strip.setPixelColor(num1,0,0,255); //设置蓝色
strip.show(); //显示
delay(500);
MicroPython示例
注意:彩灯位置是从"0"开始计算,如控制N个彩灯,依次为np[0]...np[n-1]
import neopixel
np=neopixel.NeoPixel(pin0,4) #pin0为控制引脚,级联4个RGB
for i in range(4):
np[i]= (255,0,0) #设置4颗灯珠显示颜色,颜色为红
np.show() #刷新显示颜色
for i in range(4):
np[i]= (0,255,0) #设置4颗灯珠显示颜色,颜色为绿
sleep(1000)
np.show() #刷新显示颜色
for i in range(4):
np[i]= (0,0,255) #设置4颗灯珠显示颜色,颜色为蓝
sleep(1000)
np.show() #刷新显示颜色
sleep(1000)
连接图同上
