端口扩展
当主控的引脚不够用时,可用该模块通过I2C接口拓展I/O口,最大支持8个I/O引脚拓展。
- I2C数字信号通讯
- 最大支持8个I/O端口拓展
详细的寄存器操作和指令说明,可查阅芯片手册点击下载
MicroPython示例
def extIOInit(pin, mode):
i2c.write(0x20, bytearray([3]))
mode_old=i2c.read(0x20, 1)
mode_new = 0
if mode == 1:
mode_new = mode_old[0] | (1 << pin)
elif mode == 0:
mode_new = mode_old[0] & (~(1 << pin))
cfg= bytearray([0x03,mode_new])
i2c.write(0x20, cfg)
def readExtendedIO(pin):
reg=bytearray([0])
i2c.write(0x20, reg)
dat=i2c.read(0x20, 4)
return (dat[0] >> pin) & 0x01
def writeExtendedIO(pin, output):
reg=bytearray([1])
stat_old=i2c.read(0x20, 3)
stat_new = 0
if output == 1:
stat_new = stat_old[0] | (1 << pin)
elif output == 0:
stat_new = stat_old[0] & (~(1 << pin))
cfg = bytearray([0x01, stat_new])
i2c.write(0x20,cfg)
extIOInit(0,0) #pin io0 set output mode
extIOInit(1,0) #pin io1 set output mode
extIOInit(6,1) #pin io6 set input mode
buttonVal = readExtendedIO(6)
if buttonVal == 0:
writeExtendedIO(0, 1)
writeExtendedIO(1, 1)
elif buttonVal == 1:
writeExtendedIO(0, 0)
writeExtendedIO(1, 0)
sleep(100)
Wire.begin();
extIOInit(0, 0); //设置IO0为输出模式
extIOInit(1, 1); //设置IO1为输入模式
// Add the main program code into the continuous loop() function
if (readExtendedIO(1) == 0)
writeExtendedIO(0, 1);
void extIOInit(byte pin, byte mode) //设置IO引脚输入输出模式。mode=0,为输出模式,mode=1,为输入模式
byte mode_old;
Wire.beginTransmission(0x20);
Wire.write(0x03);
Wire.endTransmission();
Wire.requestFrom(0x20, 1);
while (Wire.available() > 0)
mode_old = Wire.read();
byte mode_new = 0;
if (mode == 1)
mode_new = mode_old | (1 << pin);
else if (mode == 0)
mode_new = mode_old & (~(1 << pin));
byte cfg[2] = { 0x03, mode_new };
Wire.write(cfg, 2);
uint16_t readExtendedIO(byte pin) //IO读函数
byte dat[4];
Wire.write(0x00);
Wire.requestFrom(0x20, 4);
Wire.readBytes(dat, 4);
return (dat[0] >> pin) & 0x01;
void writeExtendedIO(byte pin, byte value) //IO写函数
byte stat_old[3];
Wire.write(0x01);
Wire.requestFrom(0x20, 3);
Wire.readBytes(stat_old, 3);
byte stat_new = 0;
if (value == 1)
stat_new = stat_old[0] | (1 << pin);
else if (value == 0)
stat_new = stat_old[0] & (~(1 << pin));
byte cfg[2] = { 0x01, stat_new };
Wire.write(cfg, 2);
