磁场传感器
用于检测量磁感应强度的I2C通讯类的传感器
- 磁感应范围 : -100~100mT
- 解析度: 0.1mT
- 精度: 2%
2、将磁感应棒接入模块,感应元器件(霍尔元件)位于磁感应棒的前端。
- GitHub:bluebit for mPython library
- bluebit for mPython library API: https://mpython-lib.readthedocs.io/zh/master/bluebit/index.html
from mpython import * # 导入mpython
import bluebit # 导入bluebit 模块
meter=bluebit.DelveBit(0x60) # 实例模块,根据实际I2C地址修改
value = meter.common_measure() # 测量
sleep_ms(200)Arduino
reading = Wire.read(); // receive high byte (overwrites previous reading)
reading = reading << 8; // shift high byte to be high 8 bits
Serial.println(reading); // print the reading
Serial.begin(9600); // start serial for output
}microbit
