电流传感器
用于检测量环路的电流值的I2C通讯类的传感器
- 电流范围 : -3~3A
- 解析度: 0.01A
- 精度: 3%
2、用4PIN连接线将传感器接入主控I2C接口,将耳机-鳄鱼夹线接入传感器,将红黑鳄鱼夹串联接入被测电路中。
- GitHub:bluebit for mPython library
- bluebit for mPython library API: https://mpython-lib.readthedocs.io/zh/master/bluebit/index.html
from mpython import * # 导入mpython
import bluebit # 导入bluebit 模块
meter=bluebit.DelveBit(0x60) # 实例模块,根据实际I2C地址修改
value = meter.common_measure() # 测量
sleep_ms(200)Arduino
reading = Wire.read(); // receive high byte (overwrites previous reading)
reading = reading << 8; // shift high byte to be high 8 bits
Serial.println(reading); // print the reading
Serial.begin(9600); // start serial for output
