4位7段LED数码管显示,可显示整形数字
- 接口方式:I2C接口
| VCC |
| SDA |
I2C数据
| SCL |
I2C时钟
| GND |
TM1650数码管库下载
//程序功能:数码管每秒显示8.8.8.8. 0.5S//
#include "TM1650.h"
#include <Arduino.h>
TM1650 d;
char line[] = {"8888"};
Wire.begin();
d.init(); //数码管初始化
d.displayOff(); //关闭显示
d.displayString(line); //输入显示字符
d.setBrightness(2); //设定显示亮度
for(int i=0; i<4; i++) d.setDot(i, true); //显示小数点
d.displayOn(); //显示信息
delay(500);
delay(500);
Serial.print(1);
Python示例
_TubeTab = [
0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F,
0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71, 0x00, 0x40]
def tm1650Init():
i2c.write(0x24, bytearray([0x01]))
def tm1650DisplayUint(x):
charTemp = [0, 0, 0, 0]
x = (x if x < 10000 else 9999)
charTemp[3] = x%10
charTemp[2] = (x//10)%10
charTemp[1] = (x//100)%10
charTemp[0] = (x//1000)%10
if x < 1000:
charTemp[0] = 0x10
if x < 100:
charTemp[1] = 0x10
if x < 10:
charTemp[2] = 0x10
for i in range(0, 4):
i2c.write(0x34+i, bytearray([_TubeTab[charTemp[i]]]))
def tm1650DisplayInt(x):
x = round(x)
if x >= 0:
temp = (x if x > -999 else -999)
temp = abs(temp)
tm1650DisplayUint(temp)
if temp < 10:
i2c.write(0x36, bytearray([_TubeTab[0x11]]))
elif temp < 100:
i2c.write(0x35, bytearray([_TubeTab[0x11]]))
elif temp < 1000:
i2c.write(0x34, bytearray([_TubeTab[0x11]]))
def tm1650Clear():
i2c.write(0x34+i, bytearray([_TubeTab[0x10]]))
tm1650Init()
tm1650DisplayInt(7777)
sleep(1000)
tm1650DisplayInt(8888)
sleep(1000)
tm1650DisplayInt(9999)
sleep(1000)
tm1650DisplayInt(1111)
sleep(1000)
| Version |
Date |
Note [+]新增[-]删除[^]修复
