摇杆
具有(X,Y)2轴模拟输出,可以制作遥控器用于控制运动物体的方向、速度等互动作品
- 模拟输出:0-VCC
| A1 | X轴模拟量 |
| A0 | Y轴模拟量 |
#程序功能:用摇杆进行上下左右操控时,掌控板OLED屏显示对应的方向箭头。
| 连接示意图 |
//程序功能:根据遥感不同的值来分别控制两个LED灯的亮灭//
int analogAPin =A0;
int analogBPin =A1;
int ledredPin =2;
int ledbluePin =3;
int a,b;
pinMode(analogAPin, INPUT);
pinMode(analogBPin, INPUT);
pinMode(ledredPin, OUTPUT);
pinMode(ledbluePin,OUTPUT);
a=analogRead(analogAPin);
b=analogRead(analogBPin);
Serial.println(a);
if(a>600)
digitalWrite(ledredPin,HIGH);
digitalWrite(ledredPin,LOW);
if(b>600)
digitalWrite(ledbluePin,HIGH);
digitalWrite(ledbluePin,LOW);
摇杆模块连接P0、P1引脚,数码管连接至I2C接口。将摇杆x轴采样值显示至数码管。
_TubeTab = [
0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F,
0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71, 0x00, 0x40]
def tm1650Init():
i2c.write(0x24, bytearray([0x01]))
def tm1650DisplayUint(x):
charTemp = [0, 0, 0, 0]
x = (x if x < 10000 else 9999)
charTemp[3] = x%10
charTemp[2] = (x//10)%10
charTemp[1] = (x//100)%10
charTemp[0] = (x//1000)%10
if x < 1000:
charTemp[0] = 0x10
if x < 100:
charTemp[1] = 0x10
if x < 10:
charTemp[2] = 0x10
for i in range(0, 4):
i2c.write(0x34+i, bytearray([_TubeTab[charTemp[i]]]))
def tm1650DisplayInt(x):
x = round(x)
if x >= 0:
temp = (x if x > -999 else -999)
temp = abs(temp)
tm1650DisplayUint(temp)
if temp < 10:
i2c.write(0x36, bytearray([_TubeTab[0x11]]))
elif temp < 100:
i2c.write(0x35, bytearray([_TubeTab[0x11]]))
elif temp < 1000:
i2c.write(0x34, bytearray([_TubeTab[0x11]]))
def tm1650Clear():
i2c.write(0x34+i, bytearray([TubeTab[0x10]]))
tm1650Init()
tm1650DisplayInt(pin1.read_analog())
sleep(10)
| 程序功能:摇杆在X轴上摇,LED灯1亮;摇杆在Y轴上摇,LED灯2亮 | |
