数码管
4位7段LED数码管显示,可显示整形数字
  • 接口方式:I2C接口
TM1650数码管库下载
//程序功能:数码管每秒显示8.8.8.8. 0.5S//
#include "TM1650.h"
#include <Arduino.h>
TM1650 d;
char line[] = {"8888"};
  Wire.begin();
  d.init();  //数码管初始化
  d.displayOff(); //关闭显示
  d.displayString(line);  //输入显示字符
  d.setBrightness(2);  //设定显示亮度
  for(int i=0; i<4; i++) d.setDot(i, true);  //显示小数点
  d.displayOn();  //显示信息
  delay(500);
  delay(500);
  Serial.print(1);
Python示例
连接图
_TubeTab = [
    0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F,
    0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71, 0x00, 0x40]
def tm1650Init():
  i2c.write(0x24, bytearray([0x01]))
def tm1650DisplayUint(x):
  charTemp = [0, 0, 0, 0]
  x = (x if x < 10000 else 9999)
  charTemp[3] = x%10
  charTemp[2] = (x//10)%10
  charTemp[1] = (x//100)%10
  charTemp[0] = (x//1000)%10
  if x < 1000:
    charTemp[0] = 0x10
    if x < 100:
      charTemp[1] = 0x10
      if x < 10:
        charTemp[2] = 0x10
  for i in range(0, 4):
    i2c.write(0x34+i, bytearray([_TubeTab[charTemp[i]]]))
def tm1650DisplayInt(x):
  x = round(x)
  if x >= 0:
    temp = (x if x > -999 else -999)
    temp = abs(temp)
    tm1650DisplayUint(temp)
    if temp < 10:
      i2c.write(0x36, bytearray([_TubeTab[0x11]]))
    elif temp < 100:
      i2c.write(0x35, bytearray([_TubeTab[0x11]]))
    elif temp < 1000:
      i2c.write(0x34, bytearray([_TubeTab[0x11]]))
def tm1650Clear():
        i2c.write(0x34+i, bytearray([_TubeTab[0x10]]))
tm1650Init()
    tm1650DisplayInt(7777)
    sleep(1000)
    tm1650DisplayInt(8888)
    sleep(1000)
    tm1650DisplayInt(9999)
    sleep(1000)
    tm1650DisplayInt(1111)
    sleep(1000)
连接方法同上
程序功能:数码管的各个数位递增
