风速风向传感器
气象站专用传感器,测量风速和风向,485信号通讯。
工作电压:12V
波特率:4800bps
风速测量范围:0-35m/s(0-12级)
风向测量范围:八方位
动态响应时间:≤2秒
配件:12V-DC电源适配器、转接线等
引脚 定义
引脚 |
定义 |
GND |
地 |
VCC |
电源 |
TX |
串口发送 |
RX |
串口接收 |
气象站代码
from bluebit import WEATHER
w = WEATHER(uart_num=1,pin_tx=Pin.P16,pin_rx=Pin.P15)
def get_wind_dir():
try:
direction = w.read_wind_direction()[0]
if(direction == 0):
return "北风"
elif(direction == 1):
return "东北风"
elif(direction == 2):
return "东风"
elif(direction == 3):
return "东南风"
elif(direction == 4):
return "南风"
elif(direction == 5):
return "西南风"
elif(direction == 6):
return "西风"
elif(direction == 7):
return "西北风"
except:
pass
def get_wind_power(arg):
try:
wind_power = w.read_wind_power()
if(arg==0):
return wind_power[0]
return wind_power[1]
except:
pass
def get_rainfall():
try:
rainfall = w.read_rainfall()
return rainfall
except:
pass
print('风向:' + str(get_wind_dir()))
time.sleep(0.5)
print('风速:' + str(get_wind_power(0)))
time.sleep(0.5)
print('降雨量:' + str(get_rainfall()))
print('===')
time.sleep(1)
